How can I shell this sphere?
micfin0809
micfin0809
I have a sphere, and I want to make a case for it, how can I shell it, I've made two spheres, one a little bigger than the other, I want to remove a portion of it and the inside so it can act as a case, picture attached.
TheCADWhisperer
File>Export and then Attach your *.f3d file here.
Select Shell and then the Body in the browser (not face).
laughingcreek
one approach
micfin0809
Doesn't work, it said it would remove all the faces, even as shelling it as body.
micfin0809
How would I change this sphere diameter though?
TheCADWhisperer
See Attached Shelled Sphere. (In Wireframe view.)
Also check in shaded section view.
Right click and Edit Features to change sizes.
No faces removed
laughingcreek
edit the diameter of the circle in the sketch.  I left it undiminished, so you can just drag it.  you should lock it down with a dimension though.
did you step through the timeline?
