Creating a loft between two profiles, Rail problem
PeteDregz
Message 1 of 12
PeteDregz
Hi All, having some issues with loft. The one rail I created seems to work and the other one gives me an error :
The selected rail does not touch all of the profiles
I have tried a bunch of things but no luck. I have attached the file if someone could help with a fix please.
Many Thanks,
Replies (11)
Message 2 of 12
davebYYPCU
Hide the rail sketches, and use the edges of the body.
Can check the file later in the day...
Might help
Message 3 of 12
TheCADWhisperer
Did you turn off Capture Design History at some point?
Message 4 of 12
PeteDregz
Hi @davebYYPCU , I just tried and same result. I appreciate your help!
Message 5 of 12
PeteDregz
@TheCADWhisperer Its possible but I don't remember doing it.
Message 6 of 12
TheCADWhisperer
Multiple missing sketch constraints?
Three lines where one would suffice???
Message 7 of 12
TheCADWhisperer
Delete the profile sketches and recreate them.
They should both be in the same component (not in two different components).
Project the straight line edges from the first component. (One Projection in each sketch.)
Message 8 of 12
PeteDregz
@TheCADWhisperer
Ok, Ill clean up the sketch and give it another try. Thanks
Message 9 of 12
TrippyLighting
You should probably design the whole thing from scratch in one file so we can see how the model was built from the very beginning.
You imported the body from "the other thread" where I helped you fillet the model, but even that already did not show a complete design history.
Message 10 of 12
PeteDregz
@TrippyLighting Ok, I will redraw the part and repost the file with design history. Thanks again for your help on the last thread too!
Pete
Message 11 of 12
davebYYPCU
In addition to the other advice,
Loft rails - curves, are required to have tangent connections, your body edge fails for this reason too.
No history for the current body, I am stuck.
Might help.....
Message 12 of 12
PeteDregz
Thanks for the advice. I’m going to see if I can dig up the original drawing with all of the history. I really appreciate your help. I’ll post file as soon ASAP.
cheers,
pete
