How can i reproduce this object?
Message 1 of 12
Hy;
Anyone know how to reproduce this on fusion ? the thickness of the material is 4 mm . the others sizes doesn't matter. Thanks 🙂
Replies (11)
Message 2 of 12
davebYYPCU
Use sweep, or pipe,
You will need a 3d sketch, for the path,
Might help....
Message 3 of 12
SaeedHamza
The best thing here is the pipe command, I wouldn't use a sweep because of these curved angles, a pipe will automatically give them
Here is a screencast on how to do it ( with the sketch )
Regards
Saeed Hamza
Message 4 of 12
Thanks for the awnser . Just a question. How can i push up the front part ?
Message 5 of 12
TrippyLighting
Of corse a sweep can be used for that!
Message 6 of 12
SaeedHamza
@TrippyLighting I know, I just meant the pipe is a faster solution
Saeed Hamza
Message 7 of 12
SaeedHamza
What part?
if you want to change the length of any part, just change the length in the original sketch that was used in the pipe command
Regards
Saeed Hamza
Message 8 of 12
Thanks for the awnser . Just a question. How can i push up the front part ? ( in the z axis)  Isn't working...
Message 9 of 12
SaeedHamza
If you tried to change it after you created the pipe in the first dimensions, it won't update to the new dimensions since it was made in the sculpt environment, so you have to redo the pipe command
Regards
Saeed Hamza
Message 10 of 12
For the Z axis?
Message 11 of 12
SaeedHamza
Yes, the one in the z-axis, you can either extrude it or change the length of the sketch that was used to create the pipe
Saeed Hamza
Message 12 of 12
Thanks Guys 😄
