How can I make gears that are editable?
spooner777
spooner777
I tried the spur gear add in. It creates gears, but I cannot at a later stage edit the number of teeth. I can only delete it and create a new one. Do you guys have an idea?
Beyondforce
Hi @spooner777,
You can change the number, by double click on the pattern feature on the timeline.
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
HughesTooling
@Beyondforce wrote:
Hi @spooner777,
Cheers / Ben
Don't think that will update the diameter or the tooth form.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
To do this correctly you need an equation driven curve unfortunately Fusion doesn't have this option.
Here's an example in Solidworks, look around 9.20.
One option might be to use an external linked design, you'd still need to edit and delete but when you save the external file your design should update.
Mark
Mark Hughes
