How can I flip/reverse a body/compoment?
autodesk
Message 1 of 40
autodesk
I imported a component that was a stp, but I need it to be reversed.  I tried doing a negative scale, but that didn't work.  Any ideas?
Accepted solutions (3)
Replies (39)
Message 2 of 40
SallyYang
"Mirror" may help you to flip/reverse the body/component?
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 3 of 40
autodesk
But with mirror, I get 2 mirrored bodies.  I just want the one body mirrored and not the original one.
Message 4 of 40
I too am looking for a solution to this conundrum.
Message 5 of 40
TrippyLighting
The answer was already provided.
Imported geometry by default is imported in direct modeling mode. Simply mirror the body and delete the original. Then you can turn on the timeline, but I personally would not.
Message 6 of 40
Thank you for your answer. I already knew this method but an answer that would have helped me would've been how a model (, either imported or not,) could be flipped without then having two copies as you would if you used 'mirror'. From what you, (and others have said in this forum post,) have said, I've deduced that there is currently no such function in Fusion 360. I'll put in a suggestion to the IdeaStation once I get time. For the meantime though I'll have to use the method that you outlined above. Thank you for your time.
Message 7 of 40
AmishSolanki
It would be nice to have a option to flip the original body to maintain CAM toolpaths
SS CADCAM - www.sscadcam.com
@sscadcam
Message 8 of 40
gavdownes
Brand new to Fusion myself so I will probably word things badly. For me I highlighted the object in question in the browser itself and selected Move/Copy. 'Move Type' was set to Free Move. I could then select the arc plane which I wanted to rotate it at.
Oddly, the first few times I tried this, I couldn't do it. I think it just came down to accuracy of where I was selecting to rotate at
Message 9 of 40
robinwkurtz
Observer
Observer
If you can find out the width of the body/component you can select it and perform a move/copy. Within this feature you can flip 180degs and move it back into position with a -(width).
Worked for me as I had simple body based on an extrude of a sketch so I could easily measure the sketch width.
Best of luck!
Message 10 of 40
BrainSlugs83
Rotating 180 degrees isn't the same as flipping it. 😞
Message 11 of 40
TrippyLighting
Did you read through all the replies and still did not find a solution that works  ?
Message 12 of 40
I managed to do this, somewhat laboriously. First I did a move copy with the bottom right edge of the component selected. This allowed me to rotate it 90 degrees so that it was standing on end. Next I did another move copy and slid the component left to where I wanted it. Then I did a third move copy with the new bottom right edge selected and rotated it 90 degrees once again. It now seems to be on the plane in its new orientation. So, rotate, slide, rotate. It would be a lot nicer to have a "horizontal flip" command...
Message 13 of 40
g-andresen
Hi Paul,
I'm guessing other tools like "mirror" might help you better.
To know this, it would be good if you would show your process in a screencast once.
regards
günther
Message 14 of 40
roundhousecompany
One method I use that works pretty well is the align command. You can select the face of the body, then align it to a another part at the same position (you may have to create a construction plane at the same position if you dont have another body at that position). Once aligned, there is a "flip" command that will flip the part over on that plane
Message 15 of 40
HughesTooling
Being able to Scale by -1 would give you a mirror without the copy, but you are not allowed a negative number when scaling, but you can edit the scale and enter -1 in parameters. So first setup a non uniform scale from the point you want to mirror from, leave all factors at 1. Now open parameters and edit one of the factors to -1, body should be mirrored without creating a copy.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 16 of 40
Excellent answer and perfectly clear. Thanks!
Message 17 of 40
This doesnt work when you import a file to edit.  only works when you have a f360 file or something you built.
Message 18 of 40
HughesTooling
@Anonymous  It will work but you have to enable history after you import the file. Parameters are only available in designs with history enabled.
Mark
Mark Hughes
Message 19 of 40
What you need to do is:
1. Mirror as new body
2. Copy that new body from the browser
3. Create new component in the browser
4. Paste that body into created component
5. Remove (don't delete otherwise you have yellow warnings) not needed components
Message 20 of 40
TrippyLighting
This is indeed very cool!
This could be used and extended to create something like the panel gap tool in Autodesk Alias.
