How can I fix pattern fold errors in 123D Make?
Using 123D Make to play with a 3D model that I want to built. I want to create a pattern fold that I can then output to PDF and then print and transfer to either cardboard or foam. But I get a pattern fold error that says that the pattern fold is too big for the 8 1/2x11 paper. OK I get that. It is. But why doens't 123D just put the rest of it on another page? How do I break it up so that I can output this and move on? I'm running up against a wall here.
Any help you guys can offer is appreciated!
TrippyLighting
I just wanted to make you aware that posted this on the Fusion 360 form, not the 123D Make forum
Ooops. I thought it was a general AutoDEsk forum! Thanks! I'll repost.
TrippyLighting
On the other hand, you could also just ditch 123d Make and move over to Fusion 360 😉
innovatenate
Autodesk Support
Autodesk Support
You may try posting in the 123D Help Center, below.
https://support.123dapp.com/hc/en-us
Hope that helps!
Nathan Chandler
Principal Specialist
