How can I add a curve between 2 coils?
RyanRitten
Observer Observer
RyanRitten
Observer
Observer
I created a basic circular coil.  The image below is a zoomed in view of the coil wrapping around a cylinder.  I am trying to find a way to make the coil more of a "wave" and not have such deep spot beteene each one.  I need to 3d print this it woild be much easier if the space between each coil was not deep but instead rounded like in my image below (as seen with the red lines I drew)
Thanks!
programming2C78B
since you made the coil, just change the profile shape to include that? Or try using the Radius tool to help fill it in.
Please click "Accept Solution" if what I wrote solved your issue!
kacper.suchomski
Hi
You did not attach a file.
Kacper Suchomski
laughingcreek
just an idea-
Warmingup1953
TheCADWhisperer
@RyanRitten
Maybe you can adapt this to your Design Intent.
