Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Hotkey to flip joint
4 REPLIES 4
Jason9ZWED
156 Views, 4 Replies
It would be nice if there was a keyboard option to Flip components while in the joint menu. Does this key exist? If so, what is it.
Labels (2)
4 REPLIES 4
jhackney1972
in reply to: Jason9ZWED
No, there is no shortcut key for this Joint Option.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Jason9ZWED
in reply to: jhackney1972
Ok, thank you.
Is there a feature request where I could submit this as an idea?
jhackney1972
You can create a new thread and make the Title of it something like "Feature Request..... and explain your request very clearly.  Autodesk personnel read this Forum and will see it.
I can tell you that is highly unlikely to get much traction because it is a small option in the dialog box of a larger command.  Most users, since they are filling in the dialog box, from top to bottom, as they place joints simply toggle it with their mouse if needed.
John Hackney
Retired
Jason9ZWED
Thanks.
I'm surprised that most users typically fill in the dialog boxes. For me, most joints are affixing holes/placing fastener elements.
