horizontal/vertical constrain on midpoints
On a midpoint of a line I want to have an horizontal/vertical constrain to another (mid)point, but the midpoints don't shown up when I hoover over the line, like it does in Inventer.
Can work around this by placing points on the midpoints or use a help line, but its more work.
Beyondforce
Hey @Anonymous ,
Use the SHIFT key and hover the mouse on top of the line and you will see the center triangle icon.
I hope it helps.
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Need a new computer? Fusion 360 Hardware Benchmark: TESREG.com
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
| YouTube
Thanks Ben, this works.
But..eh why not without pressing the shift key???
cheers Eduard
Beyondforce
Well... I'm guessing it's just to give people the option not to constrain in the middle, and if you want to constrain in the middle then you just need to hit the SHIFT key and tada... 😉
Cheers / Ben.
Ben Korez
| YouTube
