Hooks disappear when rendering model in Fusion 360
Noctyros
Noctyros
Hello everyone,
I am currently trying to render a model in Fusion 360, but I am running into a problem.
In the modeling workspace everything looks correct, but when I start the render process, the hooks on my object disappear and are no longer visible in the final render. The rest of the model renders normally.
I have already checked the visual styles and display settings, but the issue still occurs during rendering.
Has anyone experienced something similar or knows what could cause this?
Any help would be greatly appreciated.
dsouzasujay
Hi @Noctyros
This is definitely not a behavior we should see in render.
Could you please share the dataset *.f3d or *.f3z and attach here to the reply?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Noctyros
thanks for taking a look at this.
I’ve attached the .f3z file to the reply. It’s the assembly file for the project, so it should include all the referenced components.
Let me know if that works for you or if you’d also prefer the original design files.
Thanks!
kacper.suchomski
Hi
I can't reproduce this behavior on my computer.
Please restart Fusion.
Kacper Suchomski
Noctyros
thanks for checking this and for the suggestion.
I restarted Fusion 360 and now it works perfectly. 😅
Really appreciate the help!
