hollow loft to extruded truncated cylinder
jbpoole7777
Message 1 of 32
jbpoole7777
my loft keeps failing.  I am unable to select the inside end surface of the extruded hollow cylinder as a loft surface.  I suspect it has something to do with the project command but I do not understand the project command.  Any help is appreciated.  Thanks for your time.
Replies (31)
Message 21 of 32
TheCADWhisperer
@jbpoole7777 wrote:
some blue, some black
You are missing a dimension and you did something wrong with the Rectangle. (I am going to guess that you did not click ON the circle for the corner of the Rectangle.)
Attach the *.f3d file here.
Message 22 of 32
jbpoole7777
understood.  blue = no reference to origin...no constraint to origin
Message 23 of 32
TheCADWhisperer
Nope.  Could be missing any references.  Look at your Rectangle.  (Attach the *.f3d file here.)
Message 24 of 32
jbpoole7777
I am manufacturing portable cylinder shaped bluetooth speaker enclosures for personal use.  Will create enclosures with 3d printer.
Message 25 of 32
TheCADWhisperer
With what you have shown so far, with there be three parts, the central part and two end caps, or will the end caps be more than one part each end?
Are the two end caps identical, or is one end different than the other end?
Message 26 of 32
jbpoole7777
3 parts.  2 identical end caps
Message 27 of 32
TheCADWhisperer
As I suspected - you missed the circle with your rectangle.
Add a Coincident constraint between the corner of the rectangle and the cirlce.
What do you notice about the Rectangle?
Also, you added an unnecessary horizontal line from the Origin to the left.
Go ahead and leave that unnecessary line in - but change it to Construction.
Message 28 of 32
TheCADWhisperer
Nice - that will make it easy.  We will be done in 10 minutes.
Extrude the sketch 125 as shown (be sure to select inside the circle and above and below the rectangle, but not to the front of the line as shown).
Make Sketch1 visible again.
Message 29 of 32
jbpoole7777
done...and fixed my sloppy rectangle
Message 30 of 32
jbpoole7777
kids begging me to play.  will return later.  thanks for your help
Message 31 of 32
TheCADWhisperer
I made some guesses on your true Design Intent (see Attached versions).
In Version 2, I suspect that you will want the holes in the end of the Tube as a different size (threaded) than the holes in the End Cap (clearance), but since no communication - I left them both the same size.  They can be edited at any time.
I have a Loft example too.
Message 32 of 32
jbpoole7777
thanks for the designs.  I will go through both to learn how to repeat this.  I will post my final design for critique.  Thanks again.
