holes and extrusion
holes and extrusion
Message 1 of 24
holes and extrusion
Hello ,
I would like to know how can I make a hole across an extusion that is always centered when I change the height of the extrusion.
Replies (23)
Message 2 of 24
JHRendon
Hi! With the "hole" tool you can always pick the center of the piece, so it does not matter if you change the height, it will always positioned at the center.
Message 3 of 24
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
günther
Message 4 of 24
chrisplyler
There are a variety of ways to achieve such a thing, and the best way will depend on the results you want. Please show us a specific example either with pictures or by attaching your f3d file with some detailed explanation.
Message 5 of 24
Okay thanks ill look into it
Cheers
Message 6 of 24
there are two hole on the side , they dont re adjust when I change the thickness of the work
Message 7 of 24
laughingcreek
see attached. fully constraining your sketches will help.  click on the dims to change the height.  second sketch is the key to getting the holes to change position in this case
Message 8 of 24
davebYYPCU
Sketch 8 was not fully defined, and has to be to make Fusion work with paramater changes.
Change the extrude height the holes will follow, change the face width the holes will stay centred.
You needed more constraints to get it done.
Message 9 of 24
JHRendon
You should make a parameter
Also if you want to change the "8.5" dimensions you can make another parameter too
Now the holes will move, but that's due I add the dimensions to the midline on the sketch. 🙂 Check the file
Message 10 of 24
davebYYPCU
This is what happens when not fully defined.
Might help....
Message 11 of 24
JHRendon
Dear Dave, that is not the discussion. He knows how to define a sketch. Focus on the problem.
regards.
Message 12 of 24
davebYYPCU
Neither of his sketches are fully defined.  Parameter changes did not work for him,
There is another problem?
Message 13 of 24
JHRendon
 I try people understand by themselves the software and discover it. I think he knows, if not he'll ask about it.
And.. well if he did not... congratulations he knows now. Another solution for you Is that what are you looking for?
Message 14 of 24
TheCADWhisperer
regards.
The evidence would clearly indicate otherwise.
Did you reply to the correct thread?
Message 15 of 24
TheCADWhisperer
@Anonymous
Would you like to see a video of how to do this correctly in Fusion 360?
Message 16 of 24
Okay thanks mate . I will keep this in mind
Message 17 of 24
Thanks, mate, that sure will help me in the future. cheers
Message 18 of 24
Yeah you are right , nice way to make that stay at the centre!
Message 19 of 24
Im not very aware of the parameter option , could you please recommend me to something that could help me learn about parameter? Thanks
Message 20 of 24
Okay thanks, that's true. I will keep that in mind next time cheers!
