Holes Alignment
Holes Alignment
maple15207
Holes Alignment
maple15207
I have 1/4 of a pot. I am trying to remove 2 cylindrical shapes, 1 on each end. I can set the size properly and do the 2 cuts, but how do I make sure the 2 cylindrical hols are at the same height (same z value)?
Hope the attachment shows what 1 needs to resolve this.
\Thanks
TheCADWhisperer
@maple15207
You can Project the height of one to the other
or
Circular Pattern
or
use dimensions.
Are you sure your scale is correct?
SaeedHamza
The first thing you need to do is to recreate this geometry for a cleaner path down the road, as it only takes 2 minutes.
To create both holes at the same height, create an offset plane, create a sketch on it, then inside that sketch use the intersect tool with the faces of the holes selected, and that would give 2 intersection lines exactly the same height as both are on the same plane, then create a sketch on each face of the holes, project the intersection line and use it as a reference for the hole sketch circle center.
Find attached the .f3d file for you to review.
Saeed Hamza
maple15207
Thanks! I think I got them, will study them. If confused I'll be back.
rosie_lucas1
Hello @maple15207 thanks for posting in the community!
Did previous replies by @TheCADWhisperer and @SaeedHamza help clarity your question?
If yes, please mark the reply as the accepted solution. This helps other community user find a solution to similar problems.
In case you still need help, please provide an update here so we can help you best moving forward.
Rosie| Community Manager
Rosie | Community Manager
