Hole tool, selecting center of existing hole for reference
tomae
tomae
How can I select an existing hole to reference a second hole from the first?
Steps:  1) I create a block.  2) I create one hole using the hole tool (H).  I use the top and side edges to locate the first hole.  3) I then create a second hole using the hole tool.  I use the side edge for one location, my second reference is in relation to the first hole.  Is it possible to select the center of the existing hole as a reference?  I can't seem to figure out how...
-Tom
Aadithya01
http://autode.sk/2guzmAk
See the above link .. I think that is what you had asked for
tomae
No, I am trying to locate one hole, say, 0.5" from another hole.  See attached screencast.  You can see I am trying to select the center point (or any point) of the existing circle but cannot....
Aadithya01
Okay .. Now I tried that and I don't think fusion is having that option .. But It's a very good idea .. Post it in ideastation .. I think this will be given a priority and also I will be glad to give you a kudo
tomae
