Hole tool bug.
Hole tool bug.
HughesTooling
Consultant Consultant
Message 1 of 13
Hole tool bug.
HughesTooling
If you have a hole feature that uses points as the hole centre references and you delete the points for some reason you can't reselect new points. When you edit the hole feature it defaults to face selection and there's no way to change it to From Sketch multiple points even though the prompt on the hole dialog says missing face or points.
Mark
Mark Hughes
Owner, Hughes Tooling
Replies (12)
Message 2 of 13
jeff_strater
That's a good find, @HughesTooling, you seem to be on a roll today.  Will log this one, too.
Jeff
Jeff Strater
Engineering Director
Message 3 of 13
jeff_strater
reported as FUS-27111
Jeff Strater
Message 4 of 13
cirrus7-de
Just stumbled upon this one. It seems still not fixed.
Message 5 of 13
Careless_
What is the point of reporting if important features like this aren't fixed after 3 years?
Where can we read about progress on FUS-27111 and how to get around it.
This bug BREAKS modelling designs and adds hours of work to fix.
This is a mess. Please stop adding features and start fixing bugs like this.
Message 6 of 13
HughesTooling
@jeff_strater  Just run into this bug today and thought for a minute it had been fixed! 😀Now here's the crazy thing, if you only use 1 point in the hole feature you get the option to repick points if that point is deleted but if you have multiple points you don't!😠 Surely if it's this close to working correctly it can't be that hard to fix? See screencast.
Thanks Mark
Mark Hughes
Message 7 of 13
jeff_strater
@HughesTooling - FWIW, I did ping the team on this one again.  Hopefully it will see a bump in priority.  But, alas, they still won't let me set priorities for Fusion all by myself...  All I can do is advocate for things.  The more of you that see and report it, the better.
BTW, if you ever wanted to know what the equivalent of a red cape to a bull is for a software developer, it is:  " it can't be that hard to fix😆Good for at least a 10-point blood pressure spike...
Jeff Strater
Message 8 of 13
jeff_strater
this bug is in the process of being fixed now.  It will take some time to get the fix out of the pipeline, but it's coming...
Jeff Strater
Message 9 of 13
rishabh.bisht
@HughesTooling
Hi Mark,
The fix has finally landed to Fusion with June 2020 release.
You should be able to select new sketch points now, if you lose the original ones.
Rishabh Bisht
Product Owner
Message 10 of 13
HughesTooling
@rishabh.bisht @jeff_strater  Just got a chance to test this and it's not fixed.🙄 I had a duplicate sketch so deleted it thinking I could just reselect using a sketch that already existed and the bug is exactly the same as before, can't select the option from sketch.
Mark
Mark Hughes
Message 11 of 13
HughesTooling
Just did a bit more test and it seems like the problem is if you delete the sketch. If you just delete all points in a sketch and leave it empty you can reselect from a different sketch but if you just delete the sketch from the timeline you get the old bug where you can't use select from sketch.
Mark
Mark Hughes
Message 12 of 13
chrisplyler
Jeff,
Can you please detail where you guys hid the crumpled up post-it note detailing this bug such that Chad was able to find it and actually put some work in on it? This info might prove useful on getting one of the other 60,000+ bugs addressed before another three years goes by.
Asking for a friend...😂
Message 13 of 13
rishabh.bisht
@HughesTooling
Hi Mark,
Thanks for catching this and sorry for the trouble.
I can reproduce the problem and have shared this workflow with the development team to investigate.
(internal reference FUS-71466)
Rishabh Bisht
Product Owner
