Hole not centered
Hole not centered
32loyal
Hole not centered
32loyal
Hello this is my first time using Fusion360 and autodesk eagle,iam trying to just make some simple screw holes for a pcb but when i project to find the center of the hole i look at the board and the 3d board hole isnt exactly centered.When i take the circle tool and go from the center of the hole it isnt truly the center point.What am i doing wrong i attached a image so you can see exactly what is wrong.Thanks
TheCADWhisperer
Attach your file here or provide public link.
32loyal
Talking to the Eagle team they said it is a image scale issue on the PCB side,but the center of the hole on fusion is still true center
etfrench
I would export the gerbers to dxf, then import the dxf into Fusion 360 to verify.
ETFrench
