It seems there is a bug with the hole command when placing a hole on the face of a cylinder. First I want to say that I love how easy it is to place a hole on a cylindrical face with a rotation value. No need to created a rotated work plane, and then a offset tangent work plane like I am used to.
Rotating the hole on the cylindrial face works well the first time by keying in value to change the center angle, or if you use the onscreen manipulator to change the center angle.
However, if you key in a value for the center angle, that value will be the default the next time you try to place a hole on the cylindrical face. This doesn't happen if you use the on screen manipulator to change the center angle. The hole still seems to be placed on one of the quadrants of the cylinder, but you have to do some math to get the desired rotation angle.
Here is a Screencast to better show the issue.
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
