Hole command default selections
kadenaltomare
Observer Observer
kadenaltomare
Observer
Observer
Hello F360 users, I usually like to design my parts with tighter tolerances, and in the hole command whenever I make a clearance hole for something I change the fit to "close", whereas it defaults to "normal".  If it was possible to somehow set the hole command to default the fit to "close" it would save quite a few clicks, which saves time.  I have looked for a little while trying to find a solution but I cannot seem to find anything, so I have come here hoping to find a solution.  Is it possible to set the clearance hole command to automatically select the "close" fit option whenever I use it?
jhackney1972
I do not believe there is a way to change the default except maybe editing the clearance hole XML file.  I would suggest to you that once you have selected "Close" as the Fit setting, this setting is maintained for the remainder of your Fusion 360 session even if you begin a new model.
John Hackney, Retired
