Gurus
Good afternoon. I'm having an issue with the Fusion 360 software that I'm using for 3D printing. I'll convert a .jpg to a .stl file and insert it on a new sketch. Some of the lines being inserted are skewed and I'll have to edit the lines by deleting the inserted ones and creating new lines or arcs. Which the new lines are blue, and the inserted lines are green (original). Then I'll Extrude the highlighted sections to a certain depth and then to a new component. Then I'll Export, 3d Print as an .obj file and I'll import into my 3D printing slicer. When I do this i get little gaps between layer lines and I'm hoping it's a setting in the Fusion 360 I can change. I have attached pictures, and you can see the difference between the left side highlight and the right-side highlight, and it has to do with the new created lines. The right-side picture shows the highlight going past the Line, which fills the extrude. However, the 3D Printing Slicer is bringing it in and having that gap. It's as if the 3D Slicer is going Line to Line but the Extrude isn't.
