Aug 18 Update closing and opening a file
Felipe.G
Message 1 of 20
Felipe.G
Aug 18 2025 Update closing and opening a file is "jumpy" between new "file manager screen" and Icon project view at screen sides when closing a file, I haven't check if I can turn off the "new" file manager screen", but is jumpy and may need fix  sec-07   sec-29   sec-49 more or less the times were you can see the "jumpy" action, maybe "glitch" will be a better description
Thank you
(view in My Videos)
Replies (19)
Message 2 of 20
jhackney1972
I have watched your video but I do not see anything unusual.  You are not using the "Home" file manager, only the Data Panel.  What are you referring to with the statement "new file manager screen"?
John Hackney, Retired
Message 3 of 20
RajkumarIlanchelian
@Felipe.G Seconds 32 and second 43 when you close the file you see a "flash" of the home tab. is that what you are referring to as jumpy?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 4 of 20
Felipe.G
Yes that wasn't there until this new update
Message 5 of 20
RajkumarIlanchelian
@Felipe.G Can you share what version of Fusion you are on? Also, from the video it does look like you are on Windows? Can you share what version of Windows OS you are on?
Autodesk Fusion
Join Fusion Insider
Message 6 of 20
Felipe.G
You can see the "file manager screen" on the last part of the video if you start at sec-49, the others don't show a lot just the small glitch when closing, but if you look from sec-49 to the end you will see a glance of the "file manager"....I'm calling it "file manager" I don't know how to call it properly, but that wasn't there before
Message 7 of 20
Felipe.G
"Home" file manager is showing when closing more like a glitch, never seen it before until now and definitely the software wasn't behaving like this until update, thank you jhackney1972 I know now the name
Message 8 of 20
Felipe.G
I'm on Windows 10 Pro using Fusion 2603.1.52 and just received the updated in the morning, Thank you
Message 9 of 20
RajkumarIlanchelian
@Felipe.G I went back a few builds and I do see the same behavior. The home tab is sort of the first document in that tab. When you close the last document in the tab, it shows the home tab that is the first document until the next default untitled document opens. You can easily see this by opening fusion, close the unnamed document and you will see it but if you have multiple document open and you close any one of the document you will not see it.
Autodesk Fusion
Join Fusion Insider
Message 10 of 20
Felipe.G
I wonder, I use the software daily and today after updating this definitely caught my attention, I will need to check some video tutorials I made or youtube videos but I'm sure this didn't happened before until now
Message 11 of 20
RajkumarIlanchelian
I will continue to check on my end as well but the key here is that when the last document is closed you see this behavior.
Autodesk Fusion
Join Fusion Insider
Message 12 of 20
Felipe.G
I checked with the other computer that we have here with different fusion license that hasn't been updated and definitely this is not happening
Message 13 of 20
RajkumarIlanchelian
@Felipe.G Can you please tell me which version of Fusion are on those machines?
Autodesk Fusion
Join Fusion Insider
Message 14 of 20
Felipe.G
Fusion 2603.1.31 on Windows 10 Pro
Message 15 of 20
Felipe.G
Thank you Rajkumar, I wish I was able to explain it a little better from the start, but after my experience and checking with the other computer this does not even happens when closing the home menu never shows for me or as I mentioned the other computer is not showing such behavior, thank you for having a look and your follow up
Message 16 of 20
Felipe.G
Im ok ho have a zoom call if this will help, thank you
Message 17 of 20
RajkumarIlanchelian
@Felipe.G I will check on the build that you mentioned and from earlier builds too. At this time, is this problem impacting your productivity?
Autodesk Fusion
Join Fusion Insider
Message 18 of 20
Felipe.G
no but opening and closing files for 10 hrs makes it distracting and if this is a bug I will prefer to have it solved before may cause some issues
Message 19 of 20
vinayak_dhame
Hi @Felipe.G ,
Thank you for sharing this. We already have a bug raised for this behaviour FUS-193617 .
As @RajkumarIlanchelian mentioned we see "HomeTab" for a second when we close all the Tabs/documents from canvas and then opens an untitled document.
Our team do have a fix for this and the issue should be resolved in upcoming updates.
If my answer helped, please 'Accept Solution'
Vinayak Dhame
Autodesk Fusion
Message 20 of 20
Felipe.G
Thank you for the follow up
