Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Hiding components in auxilary views
2 REPLIES 2
natzoo
146 Views, 2 Replies
I use F360 to design bike frames.
The industry convention is to lay out drawings like this:
The drawing above was done in Solidworks
With F360, I can use the auxiliary views to project the seat stay and chainstay sub assembly. However I cannot hide the components:
I want to be able to hide components with the auxiliary views. Is there a way to do this?
Daniel
2 REPLIES 2
jhackney1972
in reply to: natzoo
The key to doing this is to realize that all models components placed "outside" the drawing sheet WILL NOT PRINT.  So you place one assembly out in space, suppress the components you want, and then use the Shift key when you drag the auxiliary view back in place on another assembly view.  If you want the auxiliary view lined up, which is not necessary, it will be by eye.
Edit: If you would like to create a more detail auxiliary view take a look at this Blog Article and Video.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
natzoo
in reply to: natzoo
Thank you! Very helpful
