Message 1 of 45
05:51 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to make hidden lines work in the troubled child of fusion 360, the drawings environment.
I have read the different post regarding this problem on this forum, but not found a solution for my problem.
Attached is a simple drawing (scale 1:1) of a cone. the hole inside the cone should appear as dashed lines, but is obvious solid lines. I draw the cone shape to eliminate two lines laying on top of each other, and in a size where i could have it 1:1 on the drawing sheet.
So the question is, how do i make these lines dashed?
