Message 1 of 13
Got the update error again when I start. Could someone look at the log and advise how to fix? Many Thanks!
fired up Fusion this evening and got update error again. Posted new log.
Hi @tprice71,
Thanks for the update and sharing the webdeploy log file
The following error message apears.
adsk.dls.streamer.exceptions.LockedRegistry: An installation is already in progress
This is pointing to the Windows Installer Service which is in use by another Software.
Could you may check in the "Windows Installer" Service is started and set to automatic?
I look forward hearing from you.
The Windows Installer Service is set to "manual" it is grayed out and I cant change it to automatic.
Hi @tprice71,
Thanks for the update.
This information is really helpful.
Yes, I assume that a thirdparty software like an Additional Firewall and Anti-Virus Software is blocking this Service.
Could you make sure to uninstall any Software which may disables this Service that you´ll be able to set it to automatic?
Please, keep me updated.
Hi @tprice71,
Thanks for sharing this.
Yes, the Antivirus software may cause an issue here.
I hope this information helps. Please, keep me updated once you have tested your OS
I opened Fusion 360 this evening ( using right click, run as administrator) and I get a strange error. I didn't get all of it because it flashed up then disappeared. It said something to the effect that " the terms of this account have not been met" then Fusion loads up, but without me being logged in. I noticed up in the top left of the screen it was updating, so I let it run till it finished. No errors. I then closed it down, restarted (as administrator) a log in screen appears, I sign in, and Fusion starts up, with my settings and data. I noticed again in the top left it was updating, this time it took about 10 seconds to update. No errors.
I'm still running Bit Defender, haven't changed anything since the last post.
Hi @tprice71,
Thank you for sharing your system information and the log files.
I could see multiple network and installation related errors which are probably due to the activated BitDefender Anti-Virus software.
The Windows Update and Installer service are disabled due to the installed BitDefender software.
You may miss important updates too on your OS.
I would recommend to do uninstall BitDefender for now, update your OS and do an automatic clean uninstall of Fusion 360.
Please, keep me updated. I hope this helps.
I uninstalled Bit Defender, did the clean uninstall and reinstalled, everything looks OK so far. I didn't know there was an outage going on. I will check it out when we go back online. Do you think I should not use Bit Defender anymore?
Hi @tprice71,
I´m glad that uninstalling BitDefender solved the problem.
Yes, the service outage happened yesterday night but it has been resolved.
Please, try to log into Fusion 360 everything should be running fine.
I would use the Windows Firewall and Microsoft Security Essentials which should work great.
I hope this helps.
