Help with this design
memo2022
Message 1 of 15
memo2022
Can anyone helps me to complete this design. THe practice file shows where i reached until now. Thanks
Replies (14)
Message 2 of 15
jhackney1972
I took a guess as to the model you are trying to duplicate from the Design model in your Practice model.  There are a number of differences in size but I will leave that up to you to change.  The video will show the process I used, others may do it differently.  Model attached.
John Hackney, Retired
Message 3 of 15
laughingcreek
@memo2022 - you posted this exact same question a while back, and I responded with a model.  never heard back.
Message 4 of 15
memo2022
Thanks so much for your help. For this model that was already in the file
How to make it from the model you help me with. I want also the O ring groove to be 46.128mm ID and 51.872mm OD. Thanks again so much
Message 5 of 15
jhackney1972
Edit: Please verify the O-Ring diameter is 2.872 mm and the center line diameter is 49 mm.
Message 6 of 15
jhackney1972
I did not get a confirmation from you as to the O-Ring size but I went ahead and used an O-Ring with a cross-section diameter of 2.872 mm and a center diameter of 49 mm.  I have modeled it and added it to the other model to show its location.  I removed the "tear-drop" o-ring groove and set it in the model so it is center in the o-ring groove.  I saw no purpose in the extra depth in the groove.  If this is not right simply edit the first sketch in the timeline to your liking.  Model is attached.
Message 7 of 15
memo2022
Sorry I was at work and just BACK HOME. The O ring diameter is 41mm ID 48mm OD
Message 8 of 15
memo2022
Thanks. Can you show in video how u did it please. It is more helpful for me to know so i can learn thanks
Message 9 of 15
jhackney1972
You new O-Ring dimensions fall inside the existing model walls.  Are you sure about these dimensions?  They are a far cry from what you gave me in Message #4.  If correct, do I move the wall in to accommodate and if so, what about the inside curve below the wall (7 mm dia.)?
Message 10 of 15
a.laasW8M6T
This may or may not be relevant for your application, But O-ring Grooves should be Square not round.
Refer to the parker O-ring guide for how to correctly design O-ring grooves for various applications
https://www.parker.com/content/dam/Parker-com/Literature/O-Ring-Division-Literature/ORD-5700.pdf
You probably want to look at Section 4 for Static Seals
The Handbook has the correct Groove Dimensions for Each O-ring size too
Andrew Laas
Senior Machinist, Scott Automation
Message 11 of 15
memo2022
I did not understand what you mean but the original design in the attachment (design) and my file I work in to practice this design I want it the same as this worked for me already well and I want just a last help to make this design. I am still beginner and hope you make it simple by video all details of the design is in the file and I attached it again and I want your help and hope you help me. I tried to cut the edges so I make it the same model as this
 but i could not connect all bodies together sorry i am new in this. Another issue i found is that the O ring sizes are not the same It should be 51.872 OD and 46.128 as described in the model. I attached the model again with my recent practice with you. Thanks
Message 12 of 15
memo2022
For my application it has to be round. Thanks
Message 13 of 15
memo2022
Sorry I have not received notification about it can you send the link thanks
Message 14 of 15
jhackney1972
I did the video you requested using the model I attached to Message #6.
Message 15 of 15
memo2022
