Help with Sketching a drumstick Model
thedoncutta
thedoncutta
Hello, can some one post a video modeling out the specs on this drumstick. I’m new to fusion and I’m working on this project with my percussion students. Thanks
Drumstick Specs:
Length: 17.1 inches
Diameter: .72 inches
Shaft: 12 inches
Taper: 4.25 inches
Neck at Bead: .39 inches
Bead length: .85 inches
Bead Diameter: .62 inches
Bead Shape: Taj Mahal
davebYYPCU
Draw the outline with your dimensions, change centre line to Centre line type for diameter dimensions.  Edit or add the appropriate spline for the tip.
Might help......
thedoncutta
thedoncutta
Thanks, looks easy I need crash course.
laughingcreek
start with a hand (gasp) sketch and label it with the dimensions from your spec. post a pic of that here.
davebYYPCU
Sketch was done before the pics, I missed the bead diameter if it was not an edit,
@thedoncutta use a 3 point spline now to dimension the bead diameter.
Might help....
