Help with sketch challenge
smallfavor
smallfavor
I have a construction line extending from a sketch that I want to have create a point at intersection with another sketch on a plane that's not at an orthographic position to the first.  I want the point to move on on the sketch as it's construction plane is moved up and the intersection point moves further from the axis.
https://www.screencast.com/t/r6pjhG41qq
schneik-adsk
Activate the sketch that you want the point in. I understand that you want this point to be at the intersection of the construction line and the sketch plane? To do this, under the sketch menu select, project -> Intersect.
Make sure the dialog selection filter option is set to the purple icon - "Specified Entities," and then select the construction line you want to intersect with the sketch plane.   A point will get created at the intersection of the construction line and the sketch plane.
If you move the line or the plane this point is associative and updates.
Kevin Schneider
smallfavor
Thanks for the quick response!  I had the project tool in my toolbox and wasn't seeing the other option.
