Help with Shell Command
Bob8322
Bob8322
I am currently trying to create a shell around a servo but I keep running into this specific error:
Error: The selected body appears to have already been shelled.
Please check that the body selection is correct, or that the selected body is suitable for shelling.Screen Shot 2018-03-29 at 11.52.29 AM.png
The body was created by stitching a series of face and using the boundary fill function.
I found a similar forum thread but it does not answer my question:
https://forums.autodesk.com/t5/fusion-360-design-validate/hollow-out-body/td-p/5474095
Here is the public link to the design: https://a360.co/2E4YrsM
Any help appreciated!
Sean
TheCADWhisperer
Downloading the file now, it would have been faster if you had Attached it here.
Shell should be done before the ribs, the mounting bosses, the shaft, the text....
When I open your file and do a Section Analysis I see that the assembly has already been (improperly) Shelled?
Do you have as assembly with a feature Timeline?  Or was this imported?
jeff_strater
The error message is quite accurate (I didn't know myself that we detected this case and had this specific error).  The body is indeed already shelled, you can tell if you do a section analysis.  There is also a shell feature in your feature tree:
Jeff Strater
Engineering Director
Bob8322
The object was imported as a step.
Bob8322
I didn't see the improper shell and by removing it, I am now able to create a proper shell. Thanks!
