Help with Press/pull
Sandflo
Message 1 of 12
Sandflo
Hi!
I've uploaded a screencast were I need help with a press/pull thing!
Please have a look and se if its possible to do?
http://autode.sk/1ROpJp4
Thank you very much
__________________
Gigabyte P35 V3 , Windows 8.1, Sweden
Replies (11)
Message 2 of 12
michallach81
screencast in a sec...
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 3 of 12
michallach81
screencast: http://autode.sk/1cBuGSn
should help
Michał Lach
Designer
co-author
Message 4 of 12
Sandflo
Hi!
Thank you very mucg, yes that helped!
But when i try to machibe that "pocket" that you helped me with, i try using a 3d parallel stardigy, but i can't get it work!
Could you tru to help me sith that, show me in a screencast
Thank you
__________________
Message 5 of 12
michallach81
I can try, but first can you share a model, preferably with jobs you've already done in cam?
Michał Lach
Designer
co-author
Message 6 of 12
Sandflo
Hi
Thx
https://myhub.autodesk360.com/ue29fa2ff/shares/public/SH7f1edQT22b515c761e4e956a309986bc49
Check it out, its the mustache that i want to be machined
__________________
Message 7 of 12
michallach81
Setup is a bit messy, I don't now your machine, so I can give you only some general tips based on your file. I'm little busy now, I'll get back in few hours.
Michał Lach
Designer
co-author
Message 8 of 12
jeff_strater
Here is another approach that can work, using Split Faces.  The basic idea is that you use Split Faces to split the top face using the sketch, then you can use Press/Pull to offset the resulting face.
I tried to make a screencast, but it could not upload (low bandwidth network).  So, here is a step-by-step way to do it:
start with a body and a sketch:
use Split Face:
select the top face as the Faces to Split, and the sketch as the splitting tool:
OK this command, this is the result:
start Press/Pull, and select the inner face:
Important step:  In Press/Pull, you need to select "New Offset" as the type in order to get your offset/emboss behavior.  This is kind of a weird aspect to Press/Pull - it will by default think that you are trying to modify the curve of that top face.
drag to the depth that you want:
and OK:
Hope this helps!
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 9 of 12
Sandflo
Thank you!
Yes the setup is messy!
This part is acting very strange overall, its not modelled in Fusion, maybe thats whu
And the camsetup keeps chanhing origin as soon as i leave the cam enviroment, and i cant change it back, so everytime i need to make i change in inte model enviroment, i've to delete the cam setup and start over again, so thats why,
Maybe thats why I cant get the mustache pocket to be machined proberly, Ive don stuff like this before, but now it doesn't work
My plan is to use a 3d parallel toolpath, within the containment of the mustache countor, and after that make a trace around the contour, but the parallel isnt working correct, so please have a look
Its to be machined in a 3 axis mill
__________________
Message 10 of 12
Sandflo
use Split Face:
and OK:
Hope this helps!
Thank you Jeff!
I tried the first step that michallach81 had in his screencast, and that worked fine!
Because i want the straight walls that that makes, the tip that you show is with walls perpendicular to the top face, and that is not what i want at this time, but I thank you very much for you tip, and that will come in handy in the future, thank you
__________________
Message 11 of 12
michallach81
Hi, I'm back, I've got a short vid for you. I didn't cover entire process of making this part, just made new setup and roll out defaul parallel path on face with mustaches.
To make this part you need first clear some material, plan some fixings, etc.
Screencast:
http://autode.sk/1Ii0hUq
I hope that hepled, and apologize for my english.
Michał Lach
Designer
co-author
Message 12 of 12
Sandflo
Screencast:
Thank you for your reply and help!
Regarding the milling and fixturing iisn't a problem, im a experiensed machinist.
I you wonder why i have origin in a screw hole is because its drilled in the previous operation and is a perfect to have the counterbore dailed in.
Theere seems to be a bug for me, thats why i asked if someone could help, becasue as sonn a i make a new camsetup i can pu a origin where i want, but when i leace the cam and go in to the model enviroment (don't make any changes), and then back to cam, the setup has changed origin.
But thank you very much for you help and time, I'm very cklad that you did
__________________
