Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Help with parametric design
3 REPLIES 3
potlsnekkeri
267 Views, 3 Replies
Hello
I am working on a drawing and have started with parametric design.
I have made an envelope, there must be total space that the shelf will fit.
I have drawn separate cabinets as you can see, but see that not everything is connected when I go in and change parameters?!!.
Is there anyone here who can help me clean up the model a bit so that everything is correct when I go in and change the numbers :-).
Thanks in advance ๐Ÿ™‚
https://a360.co/3QtD1MJ
3 REPLIES 3
g-andresen
in reply to: potlsnekkeri
If you want to keep an overview, divide your design into logical assemblies.
gรผnther
potlsnekkeri
Thankjs now i have orginazed abit
potlsnekkeri
here i have ground every cabinet.
how can i get the parameter to work properly?!!
