help with modelling project
grantpoadhindle
grantpoadhindle
Hello , I am trying to model this pull, can anyone give me any tips ?
I have extruded the two feet blocks as solids and tried to join a t spline pipe to these.
but its not working 😞
Thanks Grant
Oceanconcepts
You would need to convert the T-Spline body to a solid before you can Combine.
Right- mouse on the T-Spline in the browser and select Convert- the T-Spline body will remain (but visibility will be turned off) and be editable, but a solid will be generated.
- Ron
Mostly Mac- currently M1 MacBook Pro
