I have a spec sheet for King StarBoard ST here (https://www.kingplastic.com/products/king-starboard-st/). The product is an HDPE, but is stiffer than normal HDPE.
For a current project, I need to do a load flex test (two ends of a plank supported by blocks, with a known weight in the center to to determine the amount of deflection).
The problem is that the spec sheet for the King StarBoard ST does not list the characteristics that Fusion 360's Material Properties panel is asking for, specifically:
"Young's Modulus"
"Poisson's Ratio"
"Yield Strength"
"Ultimate Tensile Strength"
On the spec sheet, they do provide the following characteristics values:
"Density"
"Tensile Strength @ Yield" (I'm assuming this is the same as "Ultimate Tensile Strength")
"Tensile Modulus"
"Elongation @ Break" (probably not needed for a load flex test?)
"Elongation @ Yield"
"Flexural Modulus"
"Flexural Stress @ 5% Strain"
"Compressive Properties 10% Strain"
"Durometer"
...and others that I don't think are applicable to my test needs.
I have asked the manufacturer for the characteristics that Fusion 360 wants, but they are saying that all they have is what is in the spec sheet.
How can I convert the manufacturer's values into what Fusion 360 is asking for?
Thank you!
Jim
