Message 1 of 13
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All
Sorry if this is a basic question but something is not working has expected
Please take a look at this. I placed a 10mm circle on Top plane, then offset the top plane -4mm, place a 7mm circle on it
Then added a sketch on the from plane, intersected both circles , then placed a line between intersect points. since the line is black it should be well defined.
I then I thought if I change the diameter of the bottom circle from 7mm to 6mm , the line would remain connected to the intersect point.
The intersect point moved , but the line on the point did not move with it.
Am I expecting to much?
Cheers, Stephen
