Hello! I am a newish user. I have taught myself the program and have successfully designed stepped polymer clay cutters that print fantastically! However, I am working on trying to design cutters with a gradual tapered edge that still have a base for ergonomic use. Ideally at the top of the extrusion I end up with around a .4 mm cutting edge. Please see attached sample image of what I'm thinking. I have also attached an image of a basic 40 mm circle I made and extruded at 10 mm with a 3 deg. taper Please be kind I've only been using this program for a couple months! 😂
I can successfully taper when I extrude and add an angle. However, I cannot figure out how to give it a base as well. Any help appreciated thank you!
已解决! 转到解答。
