Help with clay/cookie cutter deign
michelledayc
michelledayc
Hello!  I am a newish user.  I have taught myself the program and have successfully designed stepped polymer clay cutters that print fantastically! However, I am working on trying to design cutters with a gradual tapered edge that still have a base for ergonomic use.  Ideally at the top of the extrusion I end up with around a .4 mm cutting edge. Please see attached sample image of what I'm thinking.  I have also attached an image of a basic 40 mm circle I made and extruded at 10 mm with a 3 deg. taper Please be kind I've only been using this program for a couple months! 😂
I can successfully taper when I extrude and add an angle.  However, I cannot figure out how to give it a base as well.  Any help appreciated thank you!
TheCADWhisperer
@michelledayc
I would use Revolve of profile for base. (Or Sweep or Extrude depending on the starting geometry.)
michelledayc
Sure thing!  Here it is!
wersy
You can extrude a surface
And use this surface to split the body
Then remove the inner body
Or revolve
g-andresen
try Revolve profile
(view in My Videos)
günther
michelledayc
Thank you!
I am not familiar with using these tools yet.  I see some others posted the same as well below!
michelledayc
I have been trying and trying but I still can't seem to figure it out even after watching the video. Any guidance welcome!
