Help with a rectangle pattern spacing equation
SlowEvo
SlowEvo
.f3d attached.
I have a series of squares(I labeled them blocks in parameters), spaced evenly with a 1mm gap between each. For every 2 squares wide, underneath will have one rectangle spanning 2 squares. I figured out an equation that spaces the rectangles correctly when the model is 6 squares wide. If I change a parameter to say 8 squares wide it the rectangles don't space out properly. Same if I reduce it to 4 squares wide.
When it works properly:
After changing to 8 squares wide:
I'm using the rectangle pattern tool(in the sketch, this better suits my need in this case).
In the rectangle pattern tool:
Quantity= countWide/2
Distance= blockWidth * ( countWide / 2 + 1 ) + ( spacingWidth * ( countWide / 2 + 1 ) )
Those parameters:
countWide=6
blockWidth=25mm
spacingWidth=1mm
All parameters:
I'm really, really bad at math and honestly am surprised I even figured out as much as I did.
Could someone please help me figure out the correct equation so it will update properly?
Also I know the amount of rectangles wide will have to be an even number.
jhackney1972
I did not want to add to your Parameter table so I added my extra equations to the Sketch Rectangular Pattern command.  I also edited your existing Parameter called "rectangularWidth".  Model attached.
John Hackney, Retired
SlowEvo
Wow thanks so much for that! One thing I dont understand is how its getting the information to add more rectangles if I add more blocks.
Edit:
I see it must have something to do with you changing Distribution to Spacing while I had it at Extent. I've never played with this option, I'll have to learn more about it and it's use cases.
SlowEvo
Included original message in edit above.
jhackney1972
As my screen capture indicates, I have created a Rectangular Pattern on the rectangular sketch.  You can add the equations to the Parameter table is you wish but since you have only a sketch, I added the required equations to the rectangular pattern dialog box.  The quantity is using one of your existing parameters.
SlowEvo
Thanks so much again!
