Help with a loft
Help with a loft
jeffescott
Advisor Advisor
Help with a loft
jeffescott
The loft works no problems there...
But I end up with an over hang, if this part was connected such that there was no overhang I would be happy.
Basically if this would machine without and undercut tool that would also be great.
The issue is in component base:1; body1
jeff_strater
you need some rails in this loft.  The default point mapping is causing bad geometry.  Rails are the best way to fix that:
Jeff Strater
Engineering Director
jeffescott
Took 3 rails per side. Think I got it now.
Gonna try breaking the loft into segments to avoid the flat spot.
thanks much.  The tutorial on 3d sketching that really helped.
