Help with a design.
Help with a design.
Help with a design.
I am having trouble making a perfect transition in a model I have been working on. I need to be able to edit this model according to various different facing curve dimensions, while still managing to have a perfect model every time. Attached are some screen shots along with a couple of the various facing curves. Essentially the baffle or the shape that I sweep along a path doesn't have to be radius, I just did that because I thought it was the only want to make that transition correct, but it doesn't seem to be working for me. I just need it to smoothly transition smoothly to the radius tip while maintaining that radius tip. Any help on how I should be doing this and editing them would be a huge help.
Here is a screenshot of what I mean.
davebYYPCU
Not clear what you want, which curve, goes where?
I have hidden the solid body, and can see an airgap here, can you describe which edge has to line up?
I actually figured it out, I just selected the radius on the lower part that wasn't flush to the tip radius and push pulled it within tolerance.
