Help with 3D contour.
justinnazzarese
Observer Observer
justinnazzarese
Observer
Observer
  • Hello, im currently trying to make a front bumper for an RC car. I found a model for the front of the car. Right now the bumper is overlapping the model and if I were to print it, there would be a lot of cutting and trimming needed to get it to fit properly. Is there a way I can use the model of the front of the car to cut away the overlapping material of the bumper.
TrippyLighting
The model you found looks like a proper quad mesh to me. That can be converted into a T-Spline and then into a surface.
That surface you can then use for trimming solid bodies, for example.
justinnazzarese
Observer
Observer
I was about to convert it into a T-spline, but i cant convert it into a surface. When i try i get an error, i try to repair the body using the auto repair but nothing happens. Any tips?error.PNGRepair body.PNG
