help understanding project to surface
I've been trying to use project to surface in a project, and have been getting unpredictable results. I've made a design where I change the shape of one spline in multiple different ways to see the effect on the projected line.
I also noticed that the behavior was sometimes different when project the edge fro a coil vs a spline in a similar shape.
I thought I'd be smart and put a description of each result in the comments, but I can't figure out how to make the comments travel with design. Apparently you can't even select the text in the comments to paste else ware, so I'll retype here.
every thing is separated into components.
Helix from coil - this is the coil whose edge is projected onto a surface of the below components
Helix from spline - this is a spline whose edge is projected onto a surface of the below components
body 1 - the base body used in all following component. in each case only the spline drawn between the edges of the 2 circles is changed.
sketch 3 of the following compoents has an edge from the coil proected on to the surface
sketch 4 of the following components has the spline projected
body2 - why don't the proected lines go all the way across?
body 3 - elongated spline handle of bootom control point. why are projected lines shorter?
body 4 - tangent handles puled so spline is oncaved
body 5 - elongated lower tangent handle from body 4
body 6 - made spline convex
body 7 - made very concaved. the projection from the spline is longer than the projection from the coil edge.
body 8 - added spline fit point to straight spline of body 2
body 9 - elongated the tangent handle of new spline fit point. both projections are shorter.
body 10 - used new fit point to make spline S shaped (same handle length as body 8). both projections are shorter, but projections are in different places. Why?
(I realize now that naming the components "Body #" is confusing. It's late, just roll with it.)
Can anybody help me understand what is going on. would like to be able to use project to surface in a predictable way.
