help to go from Body to sketch
c_d_meijer68
c_d_meijer68
Hi there,
i am tying to build a bird house but I run into trouble
can someone please convert my (fusion360) body to sketches so that I can modify them
I can send you the file, it's not big
https://a360.co/3WA788G
jhackney1972
Please attach the file to you Forum post.  The link you supplied does not allow it to be downloaded.  Open file in Fusion, select the File menu then Export to your hard drive.  Attach it to a reply.  Most of the time you can select the body, right click and choose Edit Profile Sketch from the context menu.
John Hackney, Retired
g-andresen
1. right-click on the extrusion of the body and select the profile sketch (highlighted).
2. right-click on this sketch and edit it.
günther
CGBenner
@c_d_meijer68 Hello, do you still need help with this question?
Chris Benner
