Help to build domes over curved body
diarcosb
diarcosb
Hi guys i need a simple design of a plane top dome with mini domes over it's surface.
i create the main body, but i tried to project circles over the surface but then i realized that circles makes cilinders, so i would appreciatte your help to make this,
sorry for my bad english.
TheCADWhisperer
Step 1. Start Over.
Step 2. Turn on Capture Design History.
Step 2b.  Attach new file here for Step 3 and 4.
dsouzasujay
Hi @diarcosb
As @TheCADWhisperer suggested we need to use Parametric Modelling.
Also few more things to add,
  • Insert the mesh files to the origin.
    • 'Insert Mesh' and Hit on 'Center'
  • Fully Constrain the Sketches, Add dimensions so the blue lines turn black
Creating a sketch on a surface is not possible, but it can be achieved by creating a plane at an angle.
Created below video: Hope it helps
Screencast Video: https://autode.sk/3hAnYQF
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
diarcosb
thank you so much!
