Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Help Setting Limits on Rotational Joint (f3d attached)
2 REPLIES 2
tookemtoni
178 Views, 2 Replies
Hello, I get close to setting this hinge limits of 0 to 110 degrees but how can one get it exact?  See screenshots and f3d file.
2 REPLIES 2
davebYYPCU
in reply to: tookemtoni
Zooming in on your pictures, the Joint flag is labelled with current position.
First is -7, Second is 122 degrees,
Drive Joint will read off correct numbers, too,
these (or required) numbers get plugged into Edit Joint limit options.
(Something wrong with your Maths? Or a typo?, 90 + 10 is 100.)
No access to the file for sometime.
Might help.....
jhackney1972
In the video I detail the method I would use to set the limits of movement your desire.  At the end of the video I tried to drag the movement which has the potential to overshoot the limits.  After that I animated the model and it moves correctly withing the joint limits.  If you wish a different angle simply change the angle of the plane I created.  I am attaching the model but be careful, it is an F3Z file so you must upload it to use it.  Do not overwrite your data, use a separate folder.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
