I am trying to delete a portion of a part that intersects with another faceted part.
I want to design some elements of a mask and delete the parts that extend beyond the mask while keeping the contours inside the mask so that it remains on the face. I've attached some screenshots of the project. I tried to draw a plane that intersects the mask and trace the path from the mask, but I am unable to do so.
Is there a way to draw the lines from the mask and not the other way around?
Best regards,
Alexandru
Solved by etfrench. Go to Solution.
If you want to delete the area that is outside the two vertical panels, simply use the Split Body command using a face on each of the panels as the splitting tool(s).
If you want to use the mask to delete parts of the vertical panels, then use Combine/Cut with Keep Tools checked, the vertical panels as the target bodies, and the mask as the tool.
ETFrench
