Help required adding a feature
rhys.farrell94
Message 1 of 23
rhys.farrell94
Good morning all,
I urgently require some guidance on adding a feature to a model. Im not sure im on the right path but i will share an image below on what im trying to achieve.
Ive added an ARC to the edge that i want to extrude down the edge to create a rounded edge.
What would be the workflow for this?
Thanks in advance
Replies (22)
Message 2 of 23
TrippyLighting
Sweep, possibly with guide rail, or loft.
If you want more specific advice, please share your model. Export it to a .f3d file and attach it to a post.
Message 3 of 23
rhys.farrell94
Good morning,
Many thanks for your reply.
I have attached the file just now.
I tried the sweep with rail which was almost there but left an area where it wasnt quite together.
Thanks in advance
Message 4 of 23
davebYYPCU
Sweep with these two rail selections, change distance option to Full Extents.
If requiring thickness, either use Thicken, or draw the required shape to supplement the curved face.
Might help...
Message 5 of 23
rhys.farrell94
Excellent thank you!
Thats exactly what im looking for!
The only problem is, it wont let me select more than one rail...is there something im missing?
Message 6 of 23
davebYYPCU
Click on down arrow, to select correct version.
Down arrow at Perpendicular, will allow Full Extents.
Might help...
Message 7 of 23
TrippyLighting
Once you've arrived at a final shape, I would remodel this from scratch. This can likely be done with less than 1/3 of the timeline features.
Message 8 of 23
rhys.farrell94
I completely agree, this is the most complex i have got with fusion and is proving to be lots of trial and error with things thrown in that could be avoided.
Would it be possible to reach out to you directly on this? I completely understand if not.
Thanks in advance
Rhys
Message 9 of 23
TrippyLighting
Yes, but you can also just post it in this thread. The participants in tis thread get automatically notified of new posts in the thread.
Message 10 of 23
rhys.farrell94
I have remodelled from scratch with better success using the above methods. I greatly appreciate it!
The only issue im up against now is hollowing out my new model. I have used the shell tool but wasnt quite right and with the extrusion tool its of course on the angle.
Is there a suitable workflow for extruding that recessed area straight down?
 Thanks in advance
Message 11 of 23
TheCADWhisperer
@rhys.farrell94 wrote:
I have remodeled from scratch with better success using the above methods.
@rhys.farrell94
Can you File>Export your new *.f3d file to your local drive and then Attach it here to a Reply?
Message 12 of 23
rhys.farrell94
Many thanks for your reply. I have attached it down below.
I am trying to hollow it and maintain a wall thickness of minimum 4mm or more.
Thanks in advance
Message 13 of 23
TheCADWhisperer
@rhys.farrell94
I modeled this while I was waiting for your attachment.
I assume you want something like this.
Message 14 of 23
rhys.farrell94
Yes thats exactly what im trying to achieve. What was the workflow?
Thanks in advance! I appreciate it!
Message 15 of 23
TheCADWhisperer
@rhys.farrell94
You are doing too much work.
Start a new part file.
Create the sketch shown.
Attach progress file here for next step.
Message 16 of 23
rhys.farrell94
I have attached the file below. Thanks for your guidance on this!
Message 17 of 23
rhys.farrell94
I got this far after extruding and shell function.
Message 18 of 23
TheCADWhisperer
@rhys.farrell94
Your arc is missing a Radius Dimension.
Your angled line is missing a Coincident Constraint to the Vertical Line.
Note the color of the unconstrained geometry (your actual color might be different depending on the background color).
Message 19 of 23
TheCADWhisperer
@rhys.farrell94
Do you want the curved sides to be uniform thickness from the shell, or do you want those inside walls to be straight and thicker?
Message 20 of 23
rhys.farrell94
 I think i have got there after a bit of reading
