Help pls.
Help pls.
Help pls.
How to assembly a hole 100mm diameter with shaft 100 mm too. M6x6 Designed.
The question , why when i try to assembly the part always Have collision in interface.
Is the problem because the part design of hole or anything else ??
pls Help.
Beginner and try to learn and learn.
Brady_Fulton
A little more info would help with providing a more detailed reply, but here's a screencast that shows how you can link joints for threaded parts:
https://knowledge.autodesk.com/community/screencast/80a0e0af-b2b4-47bf-90fa-b1f4ee5dba3f
Here's a quick assembly I did with your specs. If you run a interference, there's none, but if you rotate the joint and run it again, then the threads will be crossed and there will be interference. Let me know your goal and I'll try to provide additional help.
http://a360.co/2eI5Cjk
