Help on simulation of a large steel duct, simulating its weight and temperature to get structural support locations.
Message 1 of 1
Help on simulation of a large steel duct, simulating its weight and temperature to get support locations.
I have a 3 meter by 3 meter square with 50 mm of thickness extruded to 12 meter sections of steel. I want to join several of these sections and see where the stress on the structure will be, i also want to add temperature to it.
Ideally running a hot gas through it, i know this part might not be possible here but it would be in CFD.
I want to recommend the locations for the structural supports on this large and long steel duct.
(i am a begginer in Fusion 360 simulation)
Much thanks in advance and best regards.
Replies (0)
