Help needed with Mesh
Message 1 of 8
im using a CT image of my head (stl file). i want to just create a mesh representing the skin, is this possible? i cannot seem to work with just the outer mesh, everything else is include with the file. my goal is create a mask that will fit to my face. please help
Replies (7)
Message 2 of 8
keqingsong
You can insert STL files as mesh data into Fusion 360 and then proceed to build T-Spline geometry around it.
In the model environment, click on Create Form.
Then go to Insert and select Insert Mesh
Browse to the STL you want to insert and click OK. Once it comes in, you can position it and start modeling.
There are a couple of ways to model geometry around a mesh body in Fusion 360. I think the best way for you to achieve what you want is to use the Create > Face command.
Once you've activated it, make sure you check the Object Snapoption in the command dialog box. This will allow you to create faces right on top of the mesh body. You can also give it a offset distance if you don't want the face directly touching the mesh body.
let me know if this helps.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 8
thank you. the problem im having is that i cannot create a "face" here is what im seeing
Message 4 of 8
keqingsong
Here's what i mean by create face on the body.
Keqing Song
Message 5 of 8
is there a way i can send you the file. im struggling with this
Message 6 of 8
also watching your video, as soon as i complete the face (watertight) it disappears, im not able to see or edit it again, i can only see it when i hide the mesh body
Message 7 of 8
innovatenate
Autodesk Support
Autodesk Support
It may help to modify the appearance of the mesh body so that it is transparent. Right click on the body in the browser and choose appearance to get started.
This PDF File (list of screencast videos included) may help.
PDF:
https://myhub.autodesk360.com/ue29c8e8f/docstore/permalink/DS56a43QTfd62c1cd968c5076507a8d4fc2f
Fusion Design:
http://a360.co/1xKSzLp
Take note of the pull command in the section titled "Utilize Mesh Models to improve designs in Fusion 360."
I hope that helps.
Cheers,
Nathan Chandler
Principal Specialist
Message 8 of 8
keqingsong
Invite me to your project and I will take a look. my email address is keqing.song@autodesk.com
You can invite by going to the people button in your data panel and typing out my email address and then clicking invite.
Keqing Song
