- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Been working on a project that has grown really complex. Made tons of mistakes along the way, but hobbled on to a 'finished' design.
Last minute, we found out a part is a different size from what we were told it was.
That part-size change caused a cascade of other changes - many of which were impossible for me (a novice user) to execute within the original design.
So - I was back to nearly square 1.
I copied Bodies and Components I could re-use into a new design.
Mainly just bodies, using the select priority for them. Converted back to Components after the paste operation. The ones I copies as components were "Paste New"'d into the new design.
It worked. I have another design, that uses the right size part, and I've pulled my cutlist and materials order - sent off both and we'll start cutting next week..
But then I went to tidy up the project folder. Twelve or so designs wer cluttered in the Project window, some dead-ended early and some went all the way to final design before that awful size change of a critical part. Tried to delete the old rubbish...
It seems that a bunch of designs in the Project area cannot be deleted, because they are being referenced by other designs.
I'm flabbergasted. And I have no blinking way to tell anymore what might be tied to what else, or how it's tied to that other thing...
Two questions:
1) How can a user be made aware of what references are in place between designs?
(Is there a way to get a **** LIST of them displayed, maybe?)
2) Is it possible to force the release of ALL dependencies/references external to any specific design?
(Can I "detach" my new and correct design from all other designs? Make it a standalone design?)
I searched a good couple of hours, read a lot of stuff NOT about disassociating designs fom each other...
Just can't find this info.
I suck at search terms, so probably just me, but I need your help here folks!
