Help! How do I make angled table legs?
9 REPLIES 9
Message 1 of 10
2964 Views, 9 Replies
Hi guys!
I am a student working on a project in Fusion 360, and I'm really new to the program. I've been trying to design a dining table, but I've been struggling to create the table legs. The design I wanted to use has angled legs, and whenever I try to create it, it becomes extremely distorted. I'm not sure how I should approach this. I've attached a photo of the table I am trying to replicate, which is called an "XY Base Dining Table".
If you have any tips, advice or videos to recommend, please send them- I'm really stuck, and I'd appreciate all the help I can get!
Thank you so much for your time 🙂
Labels (2)
9 REPLIES 9
Message 2 of 10
TheCADWhisperer
@Anonymous wrote:
Hi guys!
I am a student working... ...whenever I try to create it, it becomes extremely distorted.
If you have any tips, advice  ...
File >Export and then Attach the *.f3d file of your attempt here.
Has your instructor covered how to fully define a sketch?
Has your instructor covered Extrude? Sweep?
Do you have physical access to this table, or only access to pictures?
Message 3 of 10
laughingcreek
this design is easier to understand once you realize the members making up the base don't all have the same cross section-
Message 4 of 10
in reply to: TheCADWhisperer
My instructor has only really covered the basics, so I'm mainly in the dark here.
I do know how to use extrude and sweep, or at least just the basics on how to use them. However, I don't know how to define a sketch. My only attempt so far was a complete fail...  it's really embarrassing. This is my first time creating an actual design in fusion.
I don't have access to the table either. I just really liked the design of the legs, so wanted to go for something similar- it doesn't have to be completely identical. I was planning on modifying the table top a bit.
The file I attached is just of one leg I tried to create, but it was a complete fail.
Message 5 of 10
in reply to: laughingcreek
Wow, that design is perfect!
If you don't mind me asking, could you explain how you made them? Thanks so much!
Message 6 of 10
g-andresen
Just follow the timeline and double-click on a feature to get the information you need.
günther
Message 7 of 10
in reply to: g-andresen
I was just looking through the timeline! 🙂
It's very helpful, except I was a bit confused by the first step. I was wondering if I could have a more in depth explanation- there's a lot in one step, and I'm not too sure how I should start, or how to sketch lines at different angles.
Aside from that, I think I'm pretty confident to do the rest!
Message 8 of 10
g-andresen
maybe this helps:
Enable 3-D-sketch in the Sketch Palette.
günther
Message 9 of 10
laughingcreek
That first skewtch in my example is a 3d sketch.  I did it that way b/c it was easier for me.  but 3d sketching in fusion is wonky sometimes.  as a new user I would suggest sticking with 2d sketches at first.  attached is one way of developing the paths for the leg using just 2d sketches (as compaired to the 1 sketch I did using 3d, which might illuminate why I chose to do it that way).
see if you can replicate this.  un-like what I did, lock everything  down with dimensions (particularly the first sketch)
Message 10 of 10
Okay, thanks so much! I think I should be able to create the table now. The method used for the table is a lot better than what I was trying to do before.
I appreciate all of your help! Have a great day.
