HELP! Fusion on my Mac just stopped.
Fusion on my Mac is frozed from a while. I didn't save anything and I'm scared that I will loose all my work. How can I fix it??
innovatenate
Autodesk Support
Autodesk Support
If you check the Activity Monitor is Fusion 360 utilizing any CPU?
You can either wait for Fusion 360 to finish computing the current command, or you can use the force quit to end Fusion 360.
Before you force quit, you may consider looking in the recovery directories (see link below for more information):
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
.....or in look in the local cache:
  • In Terminal type the command "open library" (no qoutes)
  • Browse to ~library\application support\autodesk\autodesk fusion 360\...\..
  • Search for all F3D or F3Z files.
I hope that helps!
Nathan Chandler
Principal Specialist
